Help needed, fellow Peugeot owners! Ever since my little Peugeot went on a continuous uphill drive for over an hour a few days ago, it's been having issues. The RPMs go up, but the speed doesn't. It's not too bad when not on the highway, as pressing the accelerator quickly gets the RPMs and speed up. But once I'm on the highway and going over 80-90 km/h, I need to press the gas to at least 2000 RPMs for the speed to increase very slowly. On inclines, if I don't reach 2500 RPMs, the speed drops. I never had to go over 2000 RPMs on the highway before. What's going on? 🌹
How does the FJ perform on the highway? What's the engine RPM at a speed of 120 mph?
Peugeot 206, 1.6L, automatic/manual transmission, 2006 model. The acceleration is very slow, and when you give it more gas, the RPM goes up, but the speed doesn't catch up. What's going on? Can any experts help explain this? Thanks!
I bought an '09 Accent and it's burning oil. What should I do? At 80 mph, the RPM is over 2000, and when I accelerate more, it vibrates a bit. Is there a problem? Can it go on the highway?
4Why can't the Pajero burn out when the brake is fully pressed and the accelerator is fully pressed in D gear, with the RPM only reaching a bit over 2000?
5It's uncomfortable going over speed bumps, it's very bumpy. What's up with the suspension?
6When starting a cold car, the RPM goes up to 2000 and then drops to 1500 but doesn't go any lower. The high idle speed is causing high fuel consumption, 20 liters for 300 kilometers! The idle speed is too high, and so is the fuel consumption. Can any experts provide a solution? 🙏
7When I start the car, the idle speed is around 2000 RPM, but after a while, it drops to 1500 RPM. It takes quite a long time to go down to around 1000 RPM. Does anyone know what's going on?
8Hi everyone, I have a 2013 Suzuki Alto automatic. When I start and just slightly press the accelerator, the RPM quickly goes up to 2000. Even when the speed reaches 60, the RPM stays around 2000. What's going on here?
9Is it normal for a 2015 Nissan Sunny manual transmission, with 80,000 kilometers, to have the RPM at 2000 when going over 70 mph in fifth gear?
10Help needed, fellow Peugeot owners! Ever since my little Peugeot went on a continuous uphill drive for over an hour a few days ago, it's been having issues. The RPMs go up, but the speed doesn't. It's not too bad when not on the highway, as pressing the accelerator quickly gets the RPMs and speed up. But once I'm on the highway and going over 80-90 km/h, I need to press the gas to at least 2000 RPMs for the speed to increase very slowly. On inclines, if I don't reach 2500 RPMs, the speed drops. I never had to go over 2000 RPMs on the highway before. What's going on? 🌹
