Have you experienced a situation where your Asian Lion's battery drains overnight, making it unable to start?
Guys, have you ever experienced this with your Multivan where the loudspeaker occasionally makes a ding sound while driving, and the volume is really loud?
I bought the car in August 2020, and now it often won't start. Is the battery drained?
Has there been a situation with your JETOUR X70 where the battery runs out of power even before reaching 500 kilometers?
4It could be that the battery is weak, especially if it's been sitting overnight. Cold temperatures can also affect the battery's performance, making it harder to start the engine. You might want to check the battery charge and connections to see if everything is in good condition.
5Is the battery of the 2020 ASX durable? Mine is only in its fourth year and it's already having issues with not starting and battery draining.
6Is there anyone else experiencing severe battery drain with their Hongqi H7? If I don't drive for four days, the car won't start due to significant battery loss.
7Does anyone know if the light inside the trunk of a Haval H2 stays on continuously when opened? If I keep it open for half a day, will it drain the battery? Some car models have a feature where the trunk light turns off automatically to prevent battery drain.
8Have you experienced a situation where your Asian Lion's battery drains overnight, making it unable to start?
9If you left your car in D gear overnight and found it without power the next morning, it could be due to the battery being drained. Does anyone know why this happened?
10Is it normal for a Cayenne's battery to drain to the point where it can't be charged after not being used for a month in the third year? After replacing it with a new battery, it drains after about 20 days of not being used. This has happened several times. Is this normal?
