علي صالح
2024-07-02 13:28
Has anyone here changed their transmission oil? When's the best time to do it? I have a 2021 July entry-level version of the Asian Lion, and it's run a bit over 38,000 kilometers. Thanks for the help!
Comments( 10 )
حسن عبيد
حسن عبيد2024-09-25 19:05
You can change it at 80,000 to 100,000 kilometers. If you have the budget, you can also do it at 40,000 to 60,000 kilometers.
علي توفيق
علي توفيق2024-09-21 23:11
No rush to change, I haven't replaced it in 70,000 kilometers.
عبدالله ليث
عبدالله ليث2024-08-29 20:16
The manual suggests checking at 40,000 km, and only replacing it under special circumstances. Otherwise, it should be replaced at 80,000 km.
عبدالله عاطف
عبدالله عاطف2024-07-29 17:36
I haven't changed for more than 200,000!
عبد العزيز عين
عبد العزيز عين2024-07-03 19:17
About 80,000 changed for 450.
علي فؤاد
علي فؤاد2024-07-03 12:52
[Just Want Some Peace] If you maintain it so frequently, why buy a Toyota? Unless the road conditions are particularly bad, just follow the longest maintenance interval.
علي صالح
علي صالح2024-07-03 05:48
Thank you all.
سلمان توفيق
سلمان توفيق2024-07-03 04:31
I would only consider changing it if the original factory option is at least 80,000 or more.
عبدالله يوسف
عبدالله يوسف2024-07-02 17:37
I haven't even considered changing it for 70,000.
نايف جليل
نايف جليل2024-07-02 16:32
I replaced it for 40,000 with Toyo Tires CF2.
My car is a 2017 model 280T with a 1.8T engine. Currently, I spend 360 RMB on fuel, and it seems like I can only drive a little over 200 kilometers. Can someone help explain if this fuel consumption is a bit high?
I've had the car for almost a year, and it's run 34,000 kilometers. The fuel consumption is a bit high, over 9 liters. How can I solve this issue?
Could someone please help me with how to turn off the daytime running lights on the 2021 Toyota Land Cruiser Prado off-road version? Thanks a lot!
At the end of November, I replaced the control arm, steering rod, and axle assembly. Now the steering feels very light. When going over bumps, the steering wheel moves erratically. If I accelerate a bit aggressively, the steering veers off. Can someone help me out? [crying]
Hey car enthusiasts, does your KIA Pegas have the rear end wiggle when going over speed bumps or uneven roads while turning? My car is pretty stable at 120 on the highway, but when taking a turn and encountering such conditions, the rear seems to wiggle a bit. I've done the wheel alignment, but it doesn't seem to help.
Hello MDX car owners, how many liters of engine oil do you usually add during maintenance? How many kilometers can you run? I used Mobil this year, added 5 liters each time, but the oil is almost running out after just over 5000 kilometers. It's burning quite a bit, is this normal?
I bought my automatic transmission car in July 2017, and it has run 120,000 kilometers. I've replaced the battery twice, a few bulbs, the ABS wire, and the windshield washer reservoir. Now, the front windshield washer isn't working, and the steering wheel feels a bit heavy (very slightly). Regarding the 120,000 kilometers, I want to ask if anyone has experienced changes in steering wheel effort?
I got a 2021 Murano in July 2021, and just recently on a long drive, I found that the AC was blowing hot air with no cooling. After visiting the repair shop and refilling the refrigerant, the AC started cooling again. The car is just 3 years old, is it normal for the refrigerant to run out so quickly, or could there be a leak?
Is the car's resale value really like this, or is the dealership just talking nonsense? I took my dad to look at cars and was curious, so I had them estimate my 2021 Octavia Pro Premium. I bought it at the end of 2021, and it has a bit over 30,000 kilometers now. They estimated it at only 40,000? Unbelievable, losing 40,000 in a year! [facepalm][facepalm][facepalm]
