Can the Asia Lion's remote lock make the horn sound once? Currently, it only flashes the lights, making it hard to find the car.
The lock and trunk release on my Arrizo 3 remote aren't working, only the unlock function works. I changed the battery, but it's still the same. It was working fine the night before. Does anyone know what the problem might be?
Guys, I've got a problem! Sometimes when I go through the underground parking lot, I hear a "beep beep beep" sound. I check it out and find it's my car making the noise, and the yellow light flashes rapidly. The sound stops after about 10 seconds, but the yellow light keeps flashing for several minutes. It's happened more than once! Can anyone tell me what's going on? Can I turn it off? It's pretty annoying for others too.
The dashboard always switches to miles automatically. Sometimes the wiper gets stuck when pressed once, then resets after pressing again, and only wipes once after another press. When enabling the lock car beep, the keyless entry is overly sensitive, resulting in a series of beeps. 😔 Does anyone else have the same issues?
4The car battery is dead, how to lock the car doors? Currently, the mechanical key can only lock the driver's door.
5Does anyone know how to fix the electronic remote for the Kia Sportage when it's not working? I can't even open the car door, and the battery is hard to find!
6Can someone please teach me how to disable the sound that occurs once after locking the car, and how to turn off the hazard lights that flash for a period after turning off the engine?
7How to set up the lock beep for the 2019 MG ZS Global Luxury Edition? The central control is already set to lights and beep, but when locking, only the hazard lights flash without the beep. Tried all the suggestions from Douyin and Baidu, but still can't get the lock beep to work.
8The front windows of the Jetour X70 cannot be opened, and the horn alarms when the car is locked with the remote. When the unlock button on the remote is pressed and held, only the rear windows open, while the front windows do not respond. I had this issue repaired at the 4S shop before, and they said it was related to the fuse. However, the problem has occurred again just two to three months after the repair.
9How can I adjust the seatbelt warning sound on the 2021 Toyota Asia Lion Elite? The sound is too loud, how can I make it quieter?
10Can the Asia Lion's remote lock make the horn sound once? Currently, it only flashes the lights, making it hard to find the car.
