فهد خديجة
2022-07-02 18:14
Quick question: Can you enable the emergency lane-keeping assist in the lateral assist features? I turn it on, and it turns off automatically in less than two seconds. The 4S showroom test drive car does the same thing.
I had a test drive and I'm really interested in buying. I just have two questions: First, after parking and braking, the car shakes a lot. Can this be improved later? Second, how advanced is the driver assistance? The staff just glossed over it without any introduction or demonstration.
Can the 2020 2.0 Elite Edition Mitsubishi ASX be equipped with cruise control and lane keeping assist?
If you're considering the Jetour X70, there are a few things to keep in mind. Here are some pros and cons based on general feedback: Pros: 1. **Design**: The Jetour X70 is often praised for its stylish design and aesthetic appeal, which seems to be one of the reasons you're considering it. 2. **Space**: It typically offers a spacious interior, making it comfortable for families and long trips. 3. **Features**: The vehicle usually comes equipped with a range of features that enhance comfort and convenience. Cons: 1. **Manual Transmission**: If you're looking at the manual version, consider whether you prefer this over an automatic, especially in heavy traffic conditions. 2. **Brand Recognition**: Jetour might not be as well-known as some other brands, which could affect resale value and brand trust. 3. **Performance**: Depending on your expectations, the performance in terms of horsepower and Fuel economy might not match some competitors. Overall, it's important to weigh these aspects based on your personal needs and preferences. If possible, test driving both the Jetour X70 and Jetour Dasheng could help you make a more informed decision.
The difference between the "Cancel Cruise" and "Turn Off Cruise" buttons on the steering wheel of a Patrol is as follows: - **Cancel Cruise**: This button temporarily deactivates the cruise control while keeping the set speed in memory. You can resume the cruise control to the previously set speed later without having to set it again. - **Turn Off Cruise**: This button completely deactivates the cruise control system and clears the set speed from memory. To use cruise control again, you would need to set the speed anew.
I bought the 2019 Bestune T99 in September 2020. Since it was my first car purchase, I lacked experience and fell into many traps. Besides having many minor issues, I later discovered several parts were damaged. The tires were previously used, which immediately made me suspect that this car was probably a test drive vehicle. And I was right. A few days ago, I went to replace the turn signal lights and found that the wiring inside had been reconnected, and the connections were poorly done. Moreover, the production dates of the left and right turn signals were almost a year apart. (Cars from the factory have uniform dates.) After all these years, it's impossible to explain this to the dealership now! I hope everyone pays attention to details when buying a car to avoid being deceived.
In March 2021, I had a 2020 model of the Leading Version. A few days ago, while driving on the highway with the AC on, everything was fine for about an hour. Then, it started getting hotter inside the car. When I checked, the air coming out of the AC vent was disappointingly weak. Usually, setting it to level 1 is more than enough to keep things cool, and sometimes I even have to turn it off for a bit. But this time, even when I turned it up to levels 3 or 4, the cold air was still too weak. Finally, I set it to the maximum, which was barely acceptable. At the same time, the noise from the electric fan became increasingly louder. Later, when I turned it back to levels 1 or 2, there was no airflow at all. Has anyone else experienced a similar issue? How should I resolve it? I would appreciate any valuable suggestions. Thank you.
