حسين باسل
2023-05-12 12:10
What should I pay attention to if I'm considering buying a 2014 Toyota 86 with an automatic transmission?
عبد العزيز مدرسي
عبد العزيز مدرسي2024-01-12 16:54
Affordable price
عباد سعود
عباد سعود2023-06-16 16:54
Watch out for fire and flood accidents.
علي ذكي
علي ذكي2023-06-07 23:30
I also want to get a [I Want to Be Quiet].
سلمان موسى
سلمان موسى2023-06-04 16:11
The annual inspection is a problem.
I'm considering buying a used Jetour X95. I'm not sure about the warranty and other things I should pay attention to.
What should I pay attention to when changing the tires on a Subaru XV? Are there any requirements for the tire tread pattern? Looking for advice.
I bought a used 2015 1.6T V40 with 50,000 km on it. What should I pay attention to, and what areas should I maintain myself? I hope fellow car enthusiasts can give some advice.
With a monthly salary of 6000, you’re considering buying a 2013-2014 automatic Toyota 86 on installment. Can you afford to maintain it? 🥹🥹
What should I pay attention to when installing electric running boards on the Elite version with air suspension? Do I need to select the jack mode?
What should I pay attention to when buying a used car from around 2017 that has been modified?
I'm currently a college freshman and I really like the Toyota 86. I can save up to 20,000 per year. I want to know if the maintenance cost for the Toyota 86 is high. If I were to buy a used 86, which year would you recommend?
What should I pay attention to when maintaining a Vitara 1.4T automatic? Which brand of engine oil and filter is better? How often should the air conditioning filter be replaced? At how many kilometers should the original spark plugs and brake fluid be replaced, and what brand of battery is recommended to be replaced with?
I'm looking at a 2014 Toyota 86 automatic, registered in 2017 with 20,000 kilometers. It's priced at 180,000 and I've been approved for a 170,000 loan. The third-party inspection found no issues. Could anyone with experience advise if it's a good deal? Really seeking sincere advice.
