How should the 86 handle speed bumps and humps? Is the impact significant? [covering face]
Will the carbon fiber at the front of the 600LT affect its clearance significantly? I usually drive into underground garages and over speed bumps. I've driven my friend's 488 and didn't have any issues. Can the 600LT handle the same places that the 488 can?
The 2014 Model S P85 makes a rattling noise from the right side of the chassis when going over small bumps, manhole covers, and speed bumps. I've already replaced the control arms, but the noise is still there. Does anyone else have the same issue? How can it be resolved?
When driving at low speeds with the AC on, the car, which has over 30,000 kilometers, experiences significant vibrations. This is particularly noticeable when frequently reversing or making turns. The steering wheel, door handle, and seats all vibrate. Everything is normal when the AC is off. Sometimes, when idling with the AC on, there's a loud buzzing sound that feels overwhelming to the ears and head! I always use 95-octane fuel. Have you encountered this issue? How should it be addressed?
4How should the 86 handle speed bumps and humps? Is the impact significant? [covering face]
5How should I choose between the 86 and the CT5? I want to modify it for fun, but I'm also worried that two doors might not be practical enough.
6How should I handle the maintenance and repair for HiPhi now?
7Driving over speed bumps at 60 km/h can indeed have an impact on your car. It might cause stress to the suspension system, tires, and potentially the alignment. It's always best to slow down for speed bumps to avoid any potential damage.
8The fuel tank switch is pressed down and won't pop back up. How should I handle this?
9After driving the Venza over bumpy roads, there's always a strange noise coming from the trunk, like something is rubbing or hitting against each other. The same noise happens when turning or going over speed bumps. I've removed all the tools from the trunk and taken off the plastic covers, but the noise is still there.
10How's the ground clearance of this car? My current ES always scrapes the speed bumps when I drive to the industrial area. Is this one any higher?
