فارس سلمان
2024-03-16 15:47
With a budget of around 100, you are looking for a 992s with four-wheel drive, in white with a red interior or in silver. At this price range, you might be able to find a used car in decent condition. The exact condition will depend on factors such as mileage, year of manufacture, and maintenance history. It's recommended to check the service record and perhaps get a professional inspection before purchasing to ensure the car's quality.
سعود ميسور
سعود ميسور2024-05-26 15:25
With 100, you can only buy a good condition pickup truck from 2020-2021.
عبدالرحمن يونس
عبدالرحمن يونس2024-03-16 16:59
Major accident
The 2018 Rolls-Royce Ghost Extended Wheelbase, with 12,000 kilometers driven and having been impounded by the court for nearly three years, would have its value affected by several factors. These include its condition after being impounded, market demand, and any depreciation over time. For an accurate valuation, I would recommend consulting with a professional appraiser or checking the current market listings for similar models.
With a budget of 90-110K, you might be able to purchase a used Maybach 450 from around the year 2010 to 2015, depending on the condition and mileage of the vehicle. Pricing can vary by market and specific features of the car.
The 2015 Volkswagen Touran with an automatic transmission uses a timing belt. It is typically recommended to replace the timing belt every 60,000 to 100,000 kilometers, depending on the manufacturer’s specifications and driving conditions. Always refer to the vehicle's manual or consult with a professional mechanic for the most accurate information.
Around 25,000, you might be able to find an automatic transmission Jetta from around 2010 to 2013, depending on the condition and mileage.
If you're looking to buy a used car with a budget of 40,000 RMB and you've got your eye on models like Lavida, Sylphy, Sagitar, and Jetta, here's a brief rundown: 1. **Lavida (朗逸)**: Known for its reliability and decent fuel economy. Look for models from around 2012-2015 for a balance of price and condition. 2. **Sylphy (轩逸)**: Comfortable and spacious, good for city driving. Consider models from 2013-2016. 3. **Sagitar (速腾)**: Offers a solid driving experience. Models from 2012-2015 could be a good fit for your budget. 4. **Jetta (捷达)**: Durable and economical, a popular choice for many. Look for models from 2012 onwards for better features. For city commuting, all these options are suitable, but it ultimately depends on your personal preference regarding style, comfort, and brand loyalty. Make sure to check the car’s condition and service history before purchasing.
If you're considering buying another car and your annual usage is around 5,000 kilometers, with a budget of 80,000 RMB, you have several options. Since you like the appearance and interior of the Peugeot 508, you might want to look for a good condition second-hand Peugeot 508 within your budget. Additionally, you could explore other compact or midsize sedans that are known for their style and comfort. Make sure to check the vehicle's service history and condition if you're opting for a used car to ensure a good purchase.
For your first time driving a 09 Mazda 6, here are some things you might want to consider: 1. **Basic Checks:** Before you start driving, check the fuel level, tire pressure, and ensure all the lights are functioning properly. 2. **Maintenance History:** If possible, review the car’s maintenance history to ensure it's up to date with regular services. 3. **Test Drive:** Take the car for a short drive to see if there are any unusual noises or vibrations. 4. **Visit a Mechanic:** If you're unsure about the car's condition, it might be a good idea to visit a mechanic for a thorough check-up. 5. **Familiarize Yourself:** Get comfortable with the car's controls, like the brakes, accelerator, and steering. Remember, safety first!
Porsche Porsche 911
Porsche 911AED 387,900 ~ 1,149,600Gasoline & Petrol
