فهد زين
2019-12-14 22:14
Which is better, the Porsche GT2 RS or the GT3 RS?
Comments( 9 )
فهد باهر2024-07-09 17:09
If your budget allows, go for the Euro-spec 992 GT3 RS. After all, the 992 is much more enjoyable to drive compared to the 991.
نايف ابراهيم2019-12-22 01:51
There's no good or bad.
One has a turbo, the other is naturally aspirated.
The GT2RS is more expensive and has better Nürburgring lap times than the GT3RS, but that doesn't mean the GT3RS is bad.
رجب خالد2019-12-19 13:43
Do you prefer naturally aspirated engines or turbocharged ones?
علياء سلمان2019-12-16 20:47
Let me put it this way, the GT3RS is priced at 2.268 million. With a 50% premium, you can get the car. The GT2RS is 3.798 million, globally limited to 1000 units, and costs nearly 7 million on the road.
حسين فارس2019-12-16 13:43
Is it appropriate to say this? Are you the kind of ultimate car enthusiast? Do you have the urge to buy a track car and compete with friends? If not and you're just showing off, then buy an expensive one. If you just want a car for commuting, then a regular 4WD will do.
أحمد عوادة2019-12-14 22:34
It depends on how you use it. Different prices tell the whole story. Are you going on a racetrack for performance? If so, the second option might be stronger. But if your skills aren't up to par, a good driver in a Macan S can still beat you.
نايف جابر2019-12-14 22:22
In terms of power, the GT2 RS is definitely more fun. It boasts a horsepower of 700, while the GT3 RS uses an older power system with 500 horsepower.
سلمان جمال2019-12-14 22:19
This car is really good. When choosing, it depends on your budget. If you have a sufficient budget, the latter option is better.
حسين يعقوبي2019-12-14 22:17
Actually, both of them are really good choices. No matter which one you pick, it depends on your own budget.
Which one is better compared to the Prado?
Which car is better and safer?
4Which is better, AT or CVT transmission?
5Which is better, Maserati or Lotus?
6Which one looks better, the Haval Jolion or the Porsche Cayenne?
7Which is better, the Mercedes-Benz E260 Coupe or the Porsche 718? I've been really torn between the two. I hope someone knowledgeable can help me out!
8Which is better, the Range Rover or the Navigator? Which one offers better value for money?
9Which is better, the Cetus or the Kicks?
10Which is better, the V60 or the V90??
