سعود زايد
سعود زايد
Mar 25
I went for a test drive at the dealership. The steering wheel felt heavy, maybe I'm not used to it. But why does it feel uncomfortable when lightly pressing the accelerator at low speeds? It's like something's holding you back from going fast, yet tempting you to press the pedal harder.
عمر ميمون
عمر ميمون2024-06-25 20:44
There's a noticeable jerkiness at low speeds. Once the RPMs increase, it gets better.
سعود ميسور
سعود ميسور2024-05-26 15:24
When using Normal mode, S and S+ require higher RPMs and experience low-speed dragging.
نايف دل
نايف دل2024-04-01 18:36
The PDK is just like this. The low-end torque is frustrating.
Why does the electronic brake on the MG GS get damaged when you press the brake pedal to release it?
Has anyone else encountered this issue? Recently, when I activate the auto hold, after the car stops, the AVH light blinks and then there's a clicking sound. It happens every time. If I press the brake harder, the sound is louder; if I press lightly, the sound is softer.
Hello, everyone. For the 2018 model with the 1.6 engine, do you find the clutch pedal heavy? Can it be adjusted?
Has anyone experienced repeated jerking at a certain RPM (mine is at 1500-1600)? Lightly pressing the accelerator to maintain this RPM causes repeated jerking, but it stops if I accelerate more or release the pedal. This issue has randomly appeared several times and then mysteriously resolved itself.
Hi everyone, when I drive fast and press the brakes a bit hard, there's a thudding sound and the brake pedal feels like it's bouncing. This doesn't happen when I'm driving slowly or pressing the brakes lightly. Is this the ABS system kicking in or is it an issue with the brake pads? Also, regarding the temperature gauge on the dashboard, I remember it used to show two bars as soon as I started the car, right in the middle, but now it takes a few minutes to gradually rise half a bar at a time. Am I remembering wrong or is the coolant level low?
Hey guys, when the car is off, should the brake pedal get harder the more you press it? My other two cars are like that, but the Patrol isn't as obvious, feels a bit soft. I changed the brake fluid last year, kind of worried. Is it the same for you? Thanks.
Fellow car enthusiasts, have you ever experienced the brake pedal bouncing back a few times when you press it down?
I have a 2016 Haval H2. Have any of you experienced a brake light fault warning when pressing the brake pedal for a long time, but the warning disappears once you restart and press the brake again?
Dear friends, can the 2023 CS35P's auto-hold function be set to turn on automatically? Or do you have to press it manually each time?
Porsche 911
Porsche 911QAR 350,000 ~ 899,500Gasoline & Petrol
