خالد جمال الدين
2024-07-28 08:41
Braking Dipping. I'm considering getting a standard 911. After a test drive of the 4S, I noticed a braking dipping issue. Even if I slowly release the brakes at the last moment, there's still a forward lurch just before coming to a stop. My current Mercedes doesn't have this issue, and neither did the Panamera I test drove earlier. Is it a matter of selecting the wrong mode, or is the car designed this way?
خالد قيس
خالد قيس2024-07-28 12:21
The 911 doesn't nod, right? Compared to my Mercedes, it doesn't nod at all. [I want to be alone]
Hi everyone, should I choose the Panamera or the 911? I'm a university student, and my family agreed to buy me a car for commuting. I'm really into both the Panamera and the 911, but I'm torn between the two. Any advice would be appreciated~
I feel like the braking on my car is a bit sluggish. Does anyone else have the same issue?
Why does my car jerk noticeably and respond slowly when I start and accelerate? 😢 It's really uncomfortable to drive. Fellow car owners, how can I solve this issue?
Hey guys, I just got my Es2000 recently, and there's a clunking noise when I brake. It seems to be coming from the brake calipers. Do any of you have the same issue?
Hello everyone, I'd like to ask something. When I cold start my car, the idle speed is quite high and when I release the brake, the power is strong and it just surges forward. But after driving for a few minutes or waiting at a few traffic lights, it starts to lose power. When I release the brake, it moves very slowly, and it only gets a bit better if I press the accelerator. It's a 2007 model with an automatic transmission.
After changing the brake fluid in my GAC GS5, the brakes failed. I thought it might be an issue with the master cylinder, so I replaced it, but the problem still wasn't solved. Can any experts offer some help?
Hi everyone, when I drive fast and press the brakes a bit hard, there's a thudding sound and the brake pedal feels like it's bouncing. This doesn't happen when I'm driving slowly or pressing the brakes lightly. Is this the ABS system kicking in or is it an issue with the brake pads? Also, regarding the temperature gauge on the dashboard, I remember it used to show two bars as soon as I started the car, right in the middle, but now it takes a few minutes to gradually rise half a bar at a time. Am I remembering wrong or is the coolant level low?
I'm planning to buy a Panamera soon. Initially, I was considering a regular Panamera with options totaling around 140. But I recently discovered that the new Active Ride can only be selected on the e-Hybrid, which is about 16 more expensive even if I forgo some options. Can any owners share whether the Active Ride feature is worth the money? Is it cost-effective?
Has anyone installed an 800-watt loudspeaker? Is there a serious noise issue after the modification? I always listen to music while driving. Does the noise really matter?
