سعود طيب
2021-08-02 04:44
Isn't it true that when a McLaren accelerates as the light turns green, it immediately exceeds the speed limit and incurs a 3-point penalty and a 200 fine?
فهد صالح
فهد صالح2021-08-03 00:11
It has a comfort mode, but it takes 2.9 seconds for the track mode to start.
Choosing between the McLaren 570S, Audi R8 Performance, Lamborghini EVO RWD, and Porsche 911 Turbo S can be tough as they're all great supercars. Here are a few things to consider: 1. **McLaren 570S**: Known for its lightweight design and exceptional handling. It's a great choice if you value driving dynamics and a unique supercar feel. 2. **Audi R8 Performance**: Offers a mix of everyday usability and supercar performance, thanks to its Quattro all-wheel drive. It's a good choice if you want a reliable and comfortable ride. 3. **Lamborghini EVO RWD**: Provides an exhilarating driving experience with its rear-wheel drive. It's ideal if you're looking for something that's both thrilling and a bit raw. 4. **Porsche 911 Turbo S**: Known for its incredible acceleration and all-around performance. It might be the best fit if you want a blend of speed, comfort, and practicality. With a budget of 3 million, you have some flexibility. Think about what you prioritize most in a supercar—whether it's handling, comfort, or outright performance—and that will guide your choice.
Fault code P0504, currently gears 1, 2, 3 are fine, but when switching to 4th gear, the car loses power when pressing the accelerator and doesn't accelerate. The RPM drops very slowly when pressing the clutch. Has anyone else experienced this?
Why can't my 2015 Hongqi H7 2.0T accelerate beyond 120 km/h on the highway? It shows "exceeds speed limit," but it used to accelerate easily before.
Taycan owners, I have a question about a feature. As you might know, in the Taycan's triple display, the middle one shows the speed by default, and when the power meter is checked, it shows acceleration and energy recovery levels—blue for acceleration and green for recovery. In my car, with the default set to normal mode, when I press the accelerator, the blue bar shows up normally. However, when I press the brake, the green bar doesn't show at all, although the car brakes fine. Does this mean my braking relies solely on mechanical brakes without energy recovery? Is there a way to set it so the green bar shows normally when braking? I'm sincerely asking for advice, thanks everyone!
When starting the Jetour X90 Zilong, the throttle response is decent, and the power comes immediately. However, after reaching 70 km/h and releasing the throttle, if you want to accelerate again, there's a 1-second delay before the power suddenly kicks in. This isn't the same as getting power instantly when you press the throttle. What's going on here?
Today, while driving, the engine warning light suddenly came on. No other lights were on, but I felt the engine trembling and it lacked power. After driving for about 150 meters, during idling at a red light, the engine vibration was quite noticeable. When the light turned green and I accelerated, the trembling became more pronounced and it lacked acceleration. I pulled over immediately, waited for about 10 minutes, and after restarting, everything was back to normal. I restarted a few times afterward and everything was fine. The last time I started the car, I drove a few kilometers home and it was normal too. Has anyone experienced this issue? Does anyone know what might be going on?
I have a 2017 automatic model with 50,000 kilometers on it. Recently, I've noticed three particularly obvious issues: 1. When starting at traffic lights, even with light acceleration, I can hear the engine howling. The fuel consumption spikes to 19.9, the engine revs up to 2000 RPM, but the acceleration is very slow. 2. When driving home from work and going up the parking ramp, I often find that even with the gas pedal pressed, there's no power. The RPM goes up to 3000, and the fuel consumption also spikes. 3. Occasionally, when starting the car, it will shake and then stall by itself. Overall, driving at speeds between 0-40 is uncomfortable, but things improve above 60, especially on the highway. Acceleration and overtaking are fine at higher speeds. It's quite frustrating. Is anyone else experiencing the same issues?
McLaren McLaren 720S
McLaren 720SAED 1,102,500 ~ 1,260,000Gasoline & Petrol
