Is there a situation where it shifts to neutral by itself when reversing in reverse gear?
The gear is constantly showing in N position. There's no response when shifting to A or reverse gear. Seeking advice from experts. What might be the issue?
Has anyone encountered a situation where the 2017 Smart car doesn't respond when put in reverse gear, and the engine warning light is on?
I need help from everyone. When shifting from neutral to D gear, there's a noticeable jolt. What's causing this issue? Thanks a lot!
4Is there a situation where it shifts to neutral by itself when reversing in reverse gear?
5Does the original factory condition of the Navara automatic transmission make a sound when shifting into reverse gear?
6The gear lever on this company car is problematic. After shifting to reverse, the detent stays in the engaged position even when you return it to neutral. You have to push it down to disengage. I didn't pay attention today, and when coasting downhill while pressing the clutch, I directly shifted to first gear without pushing the detent down. As a result, the car stalled and now it won't start at all.
7When shifting from reverse to neutral in the 2019 GA6, there's a vibration. What's causing this?
8I have a 2012 automatic, and it often shifts to neutral when reversing, but there's no issue with driving forward. Has anyone encountered this problem? What could be the issue?
9Gv80 shifts to neutral at a red light, makes a thump sound when starting.
10When shifting from D to neutral, there is a clicking sound. What could be the problem?
