عبد العزيز ميسور
2021-07-05 13:58
Can the 720s use 92 octane fuel?
Comments( 14 )
علي احمد2022-05-06 15:55
The comments are not professional! I'm telling you, you can add manure, let it ferment, and it'll go further.
سلمان حريري2022-05-05 11:35
I always serve plain water.
عبدالرحمن جمال الدين2022-05-04 12:33
I went back to my hometown and had to use 92 instead of 98 because it wasn't available. It was fine, but try to avoid it if you can! But if you're driving a 720S and filling it up with 92, how broke are you???
حسين بشار2022-05-04 00:43
I usually add freshly squeezed sunflower oil.
سلمان مهدي2021-11-02 00:59
Sure, you can add alcohol.
فهد خليفة2021-10-21 10:22
Can I use 92 diesel?
سلمان علياء2021-10-07 13:33
You can add sesame oil for extra smoothness.
20
خالد نظيف2021-08-17 22:57
Let's see if you can refuel.
فهد عبد عزيز2021-08-17 11:51
I remember the 720S can use 92, right?
عبدالرحمن مطلب2021-08-11 21:24
Isn't it sesame oil that's added?
Can the 2019 4WD model use 92 octane fuel?
Can the Vellfire use 92 octane gasoline?
4Can the 1.4T Volkswagen Touran use 92 octane gasoline?
5Can a 2011 Chang'an Volvo S40 use 92 octane fuel?
6Does the 2011 MDX use 92 or 95 octane fuel?
7Is it feasible to use 92 octane gasoline in the LC300 3.5TT?
8Can using 95-octane fuel provide a power boost for a vehicle like the Kia Sportage that specifies 93-octane (now equivalent to 92-octane)?
9Can this car use 92# fuel?
10In 2022, the car required 95 octane fuel, but for the 2024 model, it uses 92 octane fuel. I checked and it seems like nothing has changed. Why is that?
