What could be the cause of the Mazda 6 air conditioning compressor frequently cycling on and off and making loud noises?
How to turn off the automatic air conditioning?
Is it normal for a loud humming noise, similar to an air conditioner compressor, to come from the front of the car during charging?
Why does the air conditioning compressor keep making noise for a few minutes after parking and locking the car? What could be the reason?
4What could be the issue if the air conditioning compressor keeps running even when the AC switch is properly turned off? Does anyone know?
5What could be causing the loud exhaust noise in a 2010 Sportage?
6For the 2017 model, if the central control air conditioning vent is weak and you hear a loud noise from the air conditioning even when it's on maximum, but there's not much airflow, how can this be resolved?
7The 2008 model doesn't have automatic air conditioning or physical buttons for the AC, making it hard to adjust to a comfortable setting. Frequently using the screen to adjust can be distracting. Do you have any good solutions for this? Also, it's been raining a lot recently, causing more fogging. Turning on the defogger feels like hot air, and when you turn it off, you need to adjust the AC again. 🤔
8After a highway trip, there's this strange noise whenever I turn on the air conditioning. Does anyone know what might be causing it?
9What could be the cause of the Mazda 6 air conditioning compressor frequently cycling on and off and making loud noises?
10Will a damaged air resonance box affect the performance of a 2013 Mazda 6?
