عبد العزيز راضي
2024-09-13 13:30
I've replaced the brake pads and discs on my Mazda6, and also changed the brake fluid, but the brakes still feel very soft and don't stop well. What could be the issue?
عبد العزيز قابوس
عبد العزيز قابوس2024-09-30 19:15
The Mazda6 tends to be a bit soft, so when changing the oil or pump, make sure to properly remove the air; otherwise, it will become even softer.
فهد بندك
فهد بندك2024-09-16 07:25
Mazda's brakes are generally very soft.
عبد العزيز نور الله
عبد العزيز نور الله2024-09-14 18:00
Previously, my left rear brake caliper seized, but I could still drive and the pedal felt quite firm. Last week, I replaced the caliper, brake pads, and fluid, and now the pedal feels soft.
فهد بلال
فهد بلال2024-09-14 09:50
Tire
عبد العزيز بشر
عبد العزيز بشر2024-09-13 14:39
That's how the old Mazda6 is, braking early. If it doesn't work, you might need to spend some money to upgrade the brake system.
Hey car enthusiasts, I'm having some brake issues with my 2010 Volvo S80L. The brakes work fine when moving forward, but there's a chance of brake failure during short-distance reversing. A few days ago, when I changed the brake fluid, it was noticeably slow to drain out before adding the new fluid. Could it be that the brake fluid line is clogged? The brake pads are still quite thick, so I can basically rule them out. Any advice from the experts? 😬😬😬
How many kilometers do you guys usually change your brake pads? Yesterday, during maintenance, the technician said the brake pads need to be replaced, but I've only driven 40,000 kilometers. Shouldn't need to change them yet, right?
Is it necessary to change the transmission fluid for a 2010 Suzuki SX4 Hatchback 1.6 Automatic that has traveled 160,000 kilometers and hasn't had a transmission fluid change yet? The gear shifting is currently very smooth.
How often do you guys change brake fluid? Looking for advice!
Hey guys, when the car is off, should the brake pedal get harder the more you press it? My other two cars are like that, but the Patrol isn't as obvious, feels a bit soft. I changed the brake fluid last year, kind of worried. Is it the same for you? Thanks.
Hey guys, any recommendations for brake discs and pads for the 2019 model? 😊
Hello everyone! Is it necessary to change brake fluid every 40,000 kilometers? How should I choose brake fluid? Which brand should I choose?
How often should brake fluid be changed?
Did you get your brake pads and brake discs replaced at the 4S shop? How's the quality? I just got mine changed today for 2500 RMB.
