How do I change the transmission oil for a Mazda 6 AT? Should I use the circulation method or the gravity method? It's currently at 76,000 kilometers.
Do I need to change the transmission oil for a 2016 Skoda Rapid, automatic, 6-speed?
How many liters of transmission oil does the GA8 need to change? Should it be by gravity?
How many liters of oil does a Mazda 2 automatic transmission take for a gravity oil change?
4What type of transmission oil should I use for my Mazda 5? Planning to change it, thanks.
5How do you guys change the transmission oil, gravity or circulation?
6Q: For the Taurus 8AT transmission, is it necessary to use a circulation machine to change the transmission oil? Is it required to remove the oil pan for cleaning?
7How often should the transmission oil be changed?
8How do I change the transmission oil for a Mazda 6 AT? Should I use the circulation method or the gravity method? It's currently at 76,000 kilometers.
9How many kilometers should you typically change the transmission oil?
10How often should transmission fluid be changed? I bought my Outlander in July 2020, and it has been four years with only 10,000 kilometers driven. However, the dealership says it's time to change it due to the time elapsed, or else the warranty won't cover transmission issues. Has anyone here changed their transmission fluid? Did you use the mechanical circulation method or the gravity method? With just 10,000 kilometers, do I need to remove the oil pan for cleaning before changing?
