عمر رجب
2024-09-29 04:08
Hey guys, when my Xiao 6 reaches 130 km/h, the right front wheel starts shaking. The faster I go, the more it shakes. But when I let off the gas and drop below 130, it stops. What's the issue?
Comments( 6 )
عمر بلال
عمر بلال2024-09-30 12:51
It's likely an axle issue. Go and have the axle checked. Don't just replace the CV joint; if you encounter someone not skilled enough, it could make things worse. Just replace the axle directly to solve the problem.
حسين عاطف
حسين عاطف2024-09-30 09:52
Equipped with a high-speed intelligent speed limit reminder function.
عمر رجب
عمر رجب2024-09-30 00:56
The dynamic balance and brake pads are all fine.
علي إدريسي
علي إدريسي2024-09-29 23:38
If the balancing is fine, then it's the front brake discs.
خالد عثمان
خالد عثمان2024-09-29 11:09
It should be balanced.
فهد بندك
فهد بندك2024-09-29 06:50
Go get a wheel balancing done.
