حسن حكم
2024-09-08 22:56
Hey everyone, after my 2012 Mazda 6 rear-ended someone, I replaced the entire front end. After the repairs, the gaps are big, and when I'm driving at high speeds with crosswinds, there's no wind inside the car but there's wind noise. What's the issue?
Hey car enthusiasts, I've got a 2012 Mazda 5 that's had its gearbox repaired. How long can it last? Just bought it second-hand.
Is it better to buy the 2010 Acura TL with a 5-speed automatic transmission or the 2012 model with a 6-speed automatic transmission? 😂 Is there a big difference between the 5AT and 6AT? I've heard that the 6AT has more issues. Any car enthusiasts know about this?
When driving a 206 with a 1.6 automatic transmission, whether on the highway or at low speeds, the engine noise becomes very loud once the RPM exceeds 2800. There's a buzzing sound inside the cabin that is even louder than the wind noise—it's really loud! When the car is idling after warming up, there's a noticeable vibration if you hold the steering wheel or sit in the seat. What could be causing this? Looking for guidance from experts!
After turning off the engine and locking the car, the driver's side window automatically rolls down. While driving, the driver's window button is sometimes responsive and sometimes not. Whether raising or lowering, once the button is pressed, the window moves directly to the bottom and won't stop in the middle. After reaching the end, you can still hear a clicking sound inside the door panel. Is the window button broken? Could you provide a replacement tutorial, preferably with a video?
Hey fellow car enthusiasts, my car seems to be burning oil. After about 7000 km on full synthetic oil, the dipstick shows it's almost at the minimum level 😭. This has happened in the last two maintenance sessions. It's a 2017 Jeep Compass with 120,000 km over 6 years. Has anyone else experienced engine oil burning, and how did you resolve or repair it?
How to wire the electric seats upgrade for a 2012 automatic Mazda 6 Fashion Edition?
Hello everyone, I have a question: My Mazda 6 had the engine light and oil light come on after shifting to neutral while waiting at a traffic light. The idle was normal, but there was no response when I pressed the gas pedal and shifted to drive. After restarting the car, everything went back to normal. I went to the dealership, but they couldn't find any error codes. Has anyone experienced something similar? How can I fix it?
Don't rush to buy this car just yet; wait for three to four months as a new model will be released. The 2025 model will come out early next year. People are interested in this car mainly because of its zero fire risk and sincere configuration. Be prepared for the following if you decide to purchase this car: 1. The overall electricity consumption is over 20, and it might be even higher for men driving it, considering the car weighs 2 tons. 2. The car has severe nose diving when you brake, causing it to wobble a few times. 3. The sound insulation is poor; you need to close the doors with force, and dust easily gets inside the car. 4. Repair parts are as expensive as those for Mercedes-Benz and BMW. 5. The seats, while known as "Nissan Big Sofas," are not as comfortable as those in the Sylphy. 6. There are quite a few minor issues and faults, with the car's system being a significant drawback.
