محمد باسم
2024-09-25 00:25
Can the side mirrors of the 2012 Mazda6 be upgraded to those of the 2013 model? The side mirrors on the 2012 model are too small, making it hard to see and providing poor visibility. [Cover face]
عبد العزيز قابوس
عبد العزيز قابوس2024-09-30 19:09
It can be changed, the foundation is the same.
I'm an owner of a 2012 XV and haven't really been to the dealership much. A few days ago, I went to get a small part replaced, and the manager mentioned that there's a recall for this model. It requires replacing the valve springs and brake switch, but it seems too troublesome since it needs the engine to be taken out, so I didn't do it. Has anyone else gone through this? If I don't do it, will there be any impact?
Can anyone explain the difference between the 2012 and 2015 models? I'm considering getting a small Geely, and a 2014 model could save some budget.
The engine number for a Jeep Liberty is typically located on the engine block. You might find it on the side of the engine, near the oil filter, or on the front of the engine, depending on the model year. It's usually stamped into the metal, so it might require some cleaning to see it clearly.
Does the 11th model have electric folding side mirrors?
Can anyone tell me if the 2017 model automatic Xinrui comes with heated side mirrors?
It's hard to see in the side mirrors on rainy days! Any suggestions?
My 2013 model's driver side door lock isn't locking. Is it a problem with the lock itself or the electronic control? Any fellow car enthusiasts facing the same issue? How did you resolve it?
The side slip light is on for the 2012 model, what's the situation, and how much does it cost to replace it?
Is the automatic anti-glare function for the exterior rearview mirrors on all Ford models only available on the driver's side, but not on the right side?
