حسن بلال
Nov 7
Is your brake fluid cap unable to tighten? Is it normal that I can't tighten mine?
Is the handbrake of your Haima S5 working well? Mine hasn't been working properly since I bought it.
Hey car enthusiasts, I'm having some brake issues with my 2010 Volvo S80L. The brakes work fine when moving forward, but there's a chance of brake failure during short-distance reversing. A few days ago, when I changed the brake fluid, it was noticeably slow to drain out before adding the new fluid. Could it be that the brake fluid line is clogged? The brake pads are still quite thick, so I can basically rule them out. Any advice from the experts? 😬😬😬
What's the fuel consumption for your 2.4 NA engine? Mine is around 14, is that normal? It feels a bit high.
4How to deal with a fuel tank cap pull ring that won't open, and I can't find the emergency pull ring in the trunk.
5At 120 km/h, how many RPMs does your Honda City engine run at? Mine goes over 3000 RPM. Is that normal, and how can I fix it?
6Is your car key responsive? Sometimes I have to press mine several times before it works...
7Hey guys, is your app working? Mine keeps showing that it can't export data and nothing works.
8How to fix the long brake travel on a 2014 Santana? The brake pads are thick, the rear drum brakes have been tightened, and the brake fluid has been changed. Recently, the brake travel has become longer, and I'm not used to it at all. When I press the brake, it feels like there's a hissing sound under my foot. Several mechanics said they can't adjust it. Any suggestions on which part needs to be replaced? Thanks!
9Hello everyone! Is it necessary to change brake fluid every 40,000 kilometers? How should I choose brake fluid? Which brand should I choose?
10Did you get your brake pads and brake discs replaced at the 4S shop? How's the quality? I just got mine changed today for 2500 RMB.
