عبدالله محمد
عبدالله محمد
Nov 24
I've got a 2013 Mazda6, and there's a clunking noise from the chassis when accelerating at low speeds, especially in stop-and-go traffic. Has anyone else experienced this issue? How did you solve it?
حسن عبد الحكيم
حسن عبد الحكيم2024-11-28 23:10
Chassis [I want to be quiet] [I want to be quiet] [I want to be quiet].
Is anyone else having issues with the 2019 model 95's lane assist controller malfunctioning and the reverse camera not displaying a signal? How did you solve it? Any suggestions? 🙏
My Yizhi is a 2011 model produced in 2013. The chassis is quite stable, but the driving experience is too stiff due to the suspension. Any experts have tips to solve this?
Hey fellow car owners, I've got a leaky roof when it rains, feels like the drainage might be blocked. How did you guys solve this issue?
What could be causing the central lock switch on the 2018 Dongfeng Renault Koleos 2.0 to work intermittently? Has anyone else experienced this issue, and how did you solve it?
Is there a delay when starting the Renault Koleos 2019 model in cold weather? Has anyone else experienced this, and how did you solve it?
HS 30T 2WD, when driving on the highway, the steering feels sticky and doesn't return to the center, making it tiring to constantly adjust. This doesn't happen at low speeds or in hot weather. Has anyone else experienced this? How did you solve it? Some say it's an issue with the steering gear and needs a full replacement—is this true?
I recently went on a highway long trip, and after just letting the car sit for a day, I'm experiencing delayed acceleration. When I press the gas pedal, I can hear a swooshing sound from the chassis. Is it clogged again? Anyway, the instantaneous fuel consumption has increased, which is really frustrating. Has anyone else experienced this? How did you solve it?
Has anyone else experienced the issue where the car's data is turned off by default these past two days, and you have to manually turn on the network? How did you solve it?
Is there any owner who has experienced a clunking noise from the chassis when making a U-turn with the steering fully turned? I went to the 4S store, and they said it's a problem with the half axle and needs replacement. Has anyone else encountered this?
I've got a 2013 Forester and I'm hearing some clunking noises from the chassis. I already replaced the steering rack, but the issue is still there. I'm thinking about changing the shocks next, but the specialist said it's not necessary and that this noise is something the car has had since it was made. Has anyone else experienced this issue? Any advice?
Mazda 6
Mazda 6AED 72,900 ~ 134,900Gasoline & Petrol
