avatar-image
أحمد نواف
Aug 27
Which one is more worth getting, the McLaren 570 or the Lamborghini Huracan, considering the lower budget? Hope someone knowledgeable about cars can answer.
Comments( 7 )
فهد فاروق
فهد فاروق2022-06-13 11:15
A used 570 is definitely better than a Huracan.
عبد العزيز رأس
عبد العزيز رأس2022-04-23 20:28
If your budget is low, the 570 is of course an option, but you might only be able to find a used one now.
سعود لبيب
سعود لبيب2021-10-31 09:31
Low budget: McLaren or a used one with minimal mileage. High budget: Lamborghini.
خالد اسماعيل
خالد اسماعيل2021-10-10 17:41
570S is fine.
2
نايف وي
نايف وي2021-10-10 14:13
If your budget is low, go for a McLaren. If you're choosing a used one, try to pick one with lower mileage, as higher mileage McLarens might have minor issues with the engine and transmission. The Lamborghini Huracan is a bit better, but used ones are generally over 3 million, so you'd need a higher budget.
سلمان شخبوط
سلمان شخبوط2021-10-04 22:33
The price difference is too much. Where to get the license plate?
2
عبدالله نبراس
عبدالله نبراس2021-08-31 23:40
Sure, McLarens are cheaper, especially second-hand. But if you don't mind spending that extra million, the Ferrari F8 is a better choice, especially when it comes to quality control.
How to choose between the McLaren 570 and Lamborghini 610? Can any expert provide an answer?
If you're considering buying a supercar, how about the McLaren 720S or a Lamborghini?
The 600LT and the 570S are both impressive cars from McLaren, each with its own strengths. The 600LT is a more track-focused variant, offering enhanced performance and aerodynamics. It typically has more horsepower and better handling capabilities compared to the 570S. On the other hand, the 570S is known for being a more versatile sports car, providing a balance of performance and everyday usability. The choice between the two depends on your specific needs: whether you prioritize track performance or a more all-around driving experience.
How much could you lose in a year if you buy a used 570S or GT? Compared to a 458 or 650S at the same price, which one is more worth buying?
If you're looking for a supercar with a budget between 2 to 3 million RMB, there are several great options you can consider. Notably, brands like Ferrari, Lamborghini, and McLaren offer models that might fit within this range. For instance, the Ferrari Portofino or the Lamborghini Huracán are popular choices. It's best to visit a dealership to explore these models in person and get a feel for which suits your preferences and needs. Good luck with your purchase after your exams!
I have an Iveco Daily with a short wheelbase and low roof. I'm thinking of replacing the rear steel plate. What type should I go for? I usually carry about two to three tons of cargo. Hope someone with knowledge can help me out.
Is it a problem with the gearbox if sometimes the 4th gear won't shift down to the 3rd gear in a 2015 Honda City with a manual transmission? Waiting online for someone knowledgeable about cars to answer.
Which is better, the Mercedes-Benz E260 Coupe or the Porsche 718? I've been really torn between the two. I hope someone knowledgeable can help me out!
Hey guys, my Levante's trunk lifts up just a bit (2cm) and then stops. If I manually lift it a bit more (5cm) and then use the key, it works again. It's really frustrating because the door is super heavy. Hoping someone knowledgeable can help me out. 😢
McLaren McLaren 570S
McLaren 570SAED 777,000Gasoline
