With a budget of 90-110K, you might be able to purchase a used Maybach 450 from around the year 2010 to 2015, depending on the condition and mileage of the vehicle. Pricing can vary by market and specific features of the car.
If you're looking to spend between 40 to 50 million yuan on a Maserati GT, specifically a well-maintained 4.7 model, you'll likely be looking at models from around the early 2010s. Keep in mind that the exact year and condition can vary based on the market and availability.
For a 12-year-old car that has already run 190,000 kilometers and is experiencing a lack of power when starting, it's generally recommended to use a high-mileage engine oil. High-mileage oils are specially formulated to help reduce oil consumption, minimize leaks and oil seepage, and reduce smoke and emissions in older engines. They also contain additives that help condition seals and protect worn engine parts. You might want to consider a 10W-40 or a 5W-30 high-mileage oil, depending on your climate and specific engine requirements. Always refer to your vehicle's manual or consult with a professional mechanic for the best advice tailored to your car's condition and needs.
4If you're considering switching to a Model X, the delivery time can vary depending on your location and the specific configuration you choose. Typically, it might take a few weeks to a few months for delivery. It's best to check directly with Tesla for the most accurate and up-to-date delivery estimates.
5With a budget of around 100, you are looking for a 992s with four-wheel drive, in white with a red interior or in silver. At this price range, you might be able to find a used car in decent condition. The exact condition will depend on factors such as mileage, year of manufacture, and maintenance history. It's recommended to check the service record and perhaps get a professional inspection before purchasing to ensure the car's quality.
6If the external circulation of your car's air conditioning system can't switch to internal circulation, it might be due to a problem with the actuator or a control switch. The cost for repair can vary depending on the make and model of the car and the specific issue. I recommend consulting a local mechanic for an accurate diagnosis and cost estimate.
7When choosing between the Tahoe and the Q7, both are good options if you're looking for a larger SUV with 7 seats and have a budget around 70k. If you're also waiting for the Enclave for a comparison, it might be worth considering its features as well. Each of these models has its own strengths, so it depends on your specific needs like performance, luxury, or space.
8Around 25,000, you might be able to find an automatic transmission Jetta from around 2010 to 2013, depending on the condition and mileage.
9I'm here to help! To adjust the maintenance reminder on your car's dashboard to match the actual mileage, you usually need to reset or update the maintenance settings. Here’s a general approach: 1. **Check the Owner's Manual**: Look for instructions specific to your car model regarding how to reset the maintenance reminder. 2. **Use the Trip Button**: In many cars, you can use the trip button on the dashboard. Press and hold it while the car is in the "On" position (but not running) until the maintenance light blinks or resets. 3. **Consult the Service Menu**: Some vehicles have a service menu accessible via the infotainment system where you can update maintenance intervals. 4. **Visit a Service Center**: If you're unsure, it's best to visit a service center or dealership. They can use diagnostic tools to reset the reminder accurately. Remember that the steps can vary depending on your car brand and model.
10I'm looking to buy a mid to high trim Ford Taurus from 2015-2017. I want the car to be in good condition with low mileage, and I'm willing to pay a bit above the market price. Planning to purchase in about a month or two since I'm currently still saving up. It's for personal use, so I'm not in a rush.
