Do you sometimes have trouble opening your car door? Has anyone else experienced this?
Has anyone experienced the driver's door window on the Scirocco only lowering a little bit when opening the door? What could be causing this issue?
I suddenly have a question, how do you open the car door if the battery is dead?
4I want to ask if anyone else has experienced this with the 720S: sometimes when I start it, a fault message pops up, but after driving for a while, it disappears on its own. When I check, it says there's no issue. Has anyone else encountered a similar situation? [Shocked]
5I have a 2017 MG GS and the airbag warning light sometimes turns on. It lights up occasionally, especially when going over speed bumps. Has anyone else experienced this issue?
6Has anyone else experienced this? Is it just me or is it a common issue?
7When you open the door of a Sportage, do the hazard lights flash?
8The 360-degree panoramic reverse view is not displaying, and sometimes there's a snowy screen. Has anyone else experienced this?
9I have a 2019 model car and after I activated and then deactivated the child lock on the rear right door, it can't be opened from the inside anymore, only from the outside. Has anyone experienced this? How did you solve it?
10Has anyone else experienced the issue where the car's data is turned off by default these past two days, and you have to manually turn on the network? How did you solve it?
