حسن ذكي
2024-08-22 20:31
What could be causing a clunking noise from the left front wheel on a 2013 Peugeot 508 2.3 while driving?
فهد صارم
فهد صارم2024-08-23 07:45
Bearing, lower control arm bushing, tire.
Is there a clunking noise from the front left when driving on bumpy roads? Has anyone experienced this issue?
Is there any fellow Haval owner experiencing a clunking noise from the front right shock absorber when driving on rough roads?
What could be causing the steering wheel of my 2009 Lancer Sport to shake left and right while driving normally?
What could cause a Peugeot 207 to sway from side to side while driving normally?
Taurus chassis noise I have a 2019 Taurus, bought in 2021, and it's now at 57,000 kilometers. Recently, there's been a serious noise coming from the chassis, and it gets worse as the weather gets hotter. When the vehicle goes over speed bumps or when the front wheels hit uneven road surfaces at different times, there's a squeaky sound from underneath, like metal rotating inside a rubber bushing. When entering the garage and turning the steering wheel left, there's a clunk noise from the front when the front wheels hit a speed bump. The same clunk noise happens when parking with the steering wheel fully turned while reversing. The noise is very uncomfortable. Any suggestions from fellow car enthusiasts? Has anyone else experienced this?
Is the Peugeot 508 from 2011 to 2013 a good purchase? Are there any common issues with it?
Does anyone know if adding ambient lights to a 2012 Peugeot 508 causes any rattling noises? Thanks in advance!
Haval H2 Red Label 1.5T has currently run 85,000 kilometers. While driving at speeds between 60 to 100 km/h, there's a vibration and noise coming from the front wheels. What could be the cause of this issue?
2018 Peugeot 308 1.6L has a clunking noise when turning the steering wheel. Replaced two shock absorbers and the left strut mount bearing, the noise reduced but it's still there.
Peugeot Peugeot 508
Peugeot 508AED 89,900 ~ 156,900Gasoline & Petrol
