My keyless entry only works on the rear side of the driver's seat. Is it broken?
Why does the keyless entry only lock but not unlock the car?
Is there no keyless entry for the front passenger seat in the Vellfire?
2020 Volkswagen T-Cross, registered in 2021, and in 2022 the keyless entry stopped working, so you can only use the remote to unlock the door. Does anyone know what might be the issue?
4Hey Swift buddies, can someone tell me where the water leak is if there's water accumulating under the rear seat on the driver's side during rainy days? There's no water anywhere else, just this spot on the left side of the rear seat.
5The keyless entry function on the GS 5 is not working properly. Approaching the vehicle no longer locks or unlocks it, and the function is unresponsive. The key fob's battery was just replaced. What's going on here?
6After leaving the 2012 Koleos in an open-air parking lot for half a month during heavy rain, the keyless entry on the front doors suddenly stopped working, while the rear doors are fine. Has anyone experienced this situation? Is it a wiring issue or are the keyless entry sensors malfunctioning? PS: It's not a key battery issue.
7My keyless entry only works on the rear side of the driver's seat. Is it broken?
8Only the driver's side keyless entry is working, and I've checked the settings, everything seems fine. The auto start-stop isn't activating anymore either, though I don't really use it. Has anyone else encountered the same issues?
9Can the rear seats be folded down? Where can I adjust the height of the driver's seat?
10My rear wiper can only spray water but doesn't move. What's the issue? Is the motor broken?
