It takes a few seconds to start, what's the reason? But when I start it again, there's no issue.
There is power in the T60 pickup truck, but sometimes it takes several attempts to start. What could be the reason for this?
When I start my car, the seatbelt indicator light flashes for a few seconds and then turns off automatically, even though I haven't fastened my seatbelt yet.
When unlocking the car, the right headlight takes 30 seconds to turn on. Is this normal or is there an issue? 🤦♂️🤦♂️🤦♂️
4My X95 manual's headlights have an issue. When I start the car and turn on the high beams, they don't work at all. But for a few seconds, they work fine. When the car is parked and I turn on the high beams, everything is fine. What could be the problem?
5Has anyone experienced starting issues with their car? This problem has been going on for over a year. I've replaced the battery, cleaned the fuel lines, changed the spark plugs, and replaced the fuel pump, but still can't find the issue. The dealership is also at a loss. Every time I try to start the car, it takes three attempts to get it running. It feels like the fuel isn't reaching the engine when starting. I'm now afraid to drive, because if the engine stalls, it'll take three attempts to start it again. 😢😢😢 Does anyone know the reason?
6When starting a cold car, it should normally take about 2 seconds, but sometimes it takes 5 or 6 seconds. Does anyone else have the same issue? Last time, I replaced a solenoid valve under warranty, but it didn't help. The warranty is about to expire, and I want to fix the problem. I have a 2019 GAC GA6 Luxury Edition.
7I have a 2015 Honda City. Sometimes it takes two or three attempts to start. What's the issue, experts?
8It takes a few seconds to start, what's the reason? But when I start it again, there's no issue.
9Has anyone with the Ariya tried the single pedal mode with economy? Have you noticed that sometimes when you start, there's no response when you press down, and it takes a few seconds before the power kicks in?
10What could be the reasons when the vehicle displays "no key" and won't start?
