Is it normal for the water temperature of a 2015 Peugeot 508 to be around 90 degrees? [crying][crying][crying]
Comments( 8 )
I want to ask, I bought a new car and have driven 2000 kilometers, the car is overheating, and the water temperature gauge shows 90 degrees. How can I solve this issue?
Is it normal for the fan of a 2015 Sharan with 150,000 km to keep running at high speed after turning off the engine and removing the key, especially after driving 30 km with the AC on? The current outside temperature is 39 degrees. Looking for advice from fellow car enthusiasts.
Has anyone experienced idle running at 1000 RPM when the temperature is 35 degrees, and then it returns to normal at 800 RPM when the temperature is 26 degrees? What's going on? Please help.
4Is it normal for the water temperature of a 2015 Peugeot 508 to be around 90 degrees? [crying][crying][crying]
5Is it normal for the idle speed of a 2015 Volkswagen Touran to rise to 900 RPM when the outside temperature is below 0 degrees while the engine is warm?
6How can I fix the issue of the engine noise being very loud when starting the Alto 1.0 when it's cold? The sound normalizes once the water temperature reaches 20 degrees.
7Does the 2015 Peugeot 508 1.8T consume engine oil?
8Hey guys, my 2014 Alto's coolant temperature doesn't go above 80 degrees. Is this normal? Should I replace the thermostat? Which one is better, the original or from Tenpu?
9Is it normal for a 2014 Peugeot 2008 1.6 automatic to have the engine temperature rise very slowly, taking over ten minutes to reach 70 degrees? Could it be that the engine oil is too thick?
10I'm selling my October 2015 Peugeot 508, 1.8T, with 130,000 km. Is anyone interested in a 508?
