أحمد داود
أحمد داود
Oct 17
In May 2023, I bought a 508L driving pleasure model, and now it has run 28,000 kilometers. It's time for the fourth maintenance. During the second maintenance in January 2024, I replaced the air filter and the air conditioning filter. In the third maintenance in July 2024, the engine oil and oil filter were changed. For the fourth maintenance, what should I replace? The maintenance manual shows that, in addition to engine oil, oil filter, air conditioning filter, and air filter, spark plugs and brake fluid also need to be replaced. Are these necessary? Is it necessary to replace the carbon canister? Thanks!
Where is the air conditioning filter in the Toyota Hilux?
The air conditioning filter in the VS8 is difficult to replace.
Is there a way to improve the maintenance of an air conditioning filter, which is difficult to maintain?
How to replace the air conditioning filter?
How do you replace the air conditioning filter? Can someone explain it?
Hey folks, does the 2015 model have an air conditioning filter? Some say it does, some say it doesn't. Has anyone replaced the air conditioning filter before?
What should I pay attention to when maintaining a Vitara 1.4T automatic? Which brand of engine oil and filter is better? How often should the air conditioning filter be replaced? At how many kilometers should the original spark plugs and brake fluid be replaced, and what brand of battery is recommended to be replaced with?
Hi, for a 2011 Suzuki Swift 1.5 automatic that's run 110,000 km, here's what you might want to consider for maintenance to avoid getting ripped off: 1. **Oil Change**: Check and replace the engine oil and oil filter. 2. **Transmission Fluid**: Inspect and possibly replace the transmission fluid. 3. **Brake System**: Check the brake pads and brake fluid. 4. **Coolant**: Inspect the coolant level and top up or replace if necessary. 5. **Air Filter**: Check the air filter and replace if dirty. 6. **Tires**: Check tire pressure and tread wear. 7. **Battery**: Test the battery to ensure it's in good condition. 8. **Belts and Hoses**: Inspect for any wear and tear. It's always a good idea to consult your vehicle's manual or a trusted mechanic for specific recommendations.
Hey guys, for a new car with 15,000 km in two years, what maintenance should be done? Just engine oil, oil filter, and air filter, right?
Peugeot 508
Peugeot 508BHD 10,600 ~ 14,495Gasoline & Petrol
