محمد أيوب
2024-07-03 13:41
How to check if the transmission oil needs to be changed?
خالد خالد
خالد خالد2024-07-10 00:00
There's a screw on the transmission; loosen it to check the color of the oil. The transmission oil should be red. If the color is not pure or it's very dark, consider changing it. Usually, replacing about 4 liters costs over 300, and with labor, it's generally around 80. You can get it done within 400.
