Car enthusiasts, on the 2021 Strength Edition, why does the trunk lock keep flashing even after the doors and trunk are closed? How can I solve this issue? Please let me know if you have any ideas. In my video, the flashing red dot is right at the trunk lock.
Experts, my Mitsubishi Galant's remote lock doesn't flash the lights, but it can still lock. The repair shop checked the hood and trunk, and everything's fine. They said my central control module is broken, but they can't find the module in the car. Any guidance from the experts would be appreciated...
Is it normal for the trunk to beep a few seconds after closing? The trunk is already locked.
The FJ keeps showing that the door is not closed. Pressing the lock button makes it beep continuously. Manually locking it works, but it still shows that the door is not closed.
4How to solve the issue of the Haima S5 trunk lock not opening?
5I recently took my 2021 manual 1.6 35p to the dealership to replace the clutch pedal. After coming back, I noticed that when I lock the car, the indicator lights flash rapidly six or seven times. Previously, they would flash slowly twice. Additionally, there's a warning about low key battery, but the key can still control the car from a distance. What's going on?
6Hey fellow car enthusiasts, my Sportage suddenly started beeping and wouldn't start, no idea what I touched. It seemed like closing the hood fixed it. Has anyone else experienced this? It's happened to me two or three times in the past couple of months. Does anyone know how to solve this?
7Hi everyone, I need some advice. The middle doors on my T6 keep having issues. Sometimes they automatically open or close halfway and then suddenly bounce back. Other times the button doesn't work at all, and the door button flashes a fault. Sometimes I have to press the button twice, holding it down on the second press until the door fully opens or closes before I can release it. What could be the problem, and how should I fix it? Please help.
8Does anyone know why the hazard lights keep flashing as soon as the car starts? How can I fix it? Please let me know.
9My 2021 Outlander's trunk suddenly won't open (can be opened with the emergency button inside). The lock button on the driver's side isn't working properly, can't lock the car. Any experts know how to fix this?
10Car enthusiasts, on the 2021 Strength Edition, why does the trunk lock keep flashing even after the doors and trunk are closed? How can I solve this issue? Please let me know if you have any ideas. In my video, the flashing red dot is right at the trunk lock.
