علي بهاء
علي بهاء
Jan 29
Is the transmission of the 2013 Mazda5 still prone to issues? I've heard that the earlier models had problems with warning lights.
خالد آسيا
خالد آسيا2023-02-23 11:16
Do I need to perform a re-calibration after cleaning the throttle body?
فهد نادر
فهد نادر2023-02-04 08:14
The transmission control module is placed in a position where the temperature tends to be high, which can easily cause issues. You can relocate it yourself. Replacing it isn't expensive either. Mine has been fine for 8 years and 90,000 kilometers.
My 2013 Touran won't start, and all the warning lights are on. Can anyone help?
Hey folks, I've heard they say it's prone to engine seizure. Is that true?
Has anyone had the engine warning light come on? How did you deal with it?
The engine warning light is on, and the idle seems unstable. The speed can still go up, but it doesn't accelerate as quickly as before. Could it be a problem with the throttle? Any insights?
Does the 10-year-old Honda City rust easily? I've heard that this car is prone to rusting.
What could be the issue if the ABS warning light is on in a 2013 Santana 1.4 manual?
Is there a problem with the Taurus battery? I've had to replace it twice in three years, and this time there's sulfuric acid leaking!
I've been driving my car for six years, and it's covered over 30,000 kilometers. Recently, while driving, the gear indicator on the dashboard disappeared, and the engine warning light came on, but the car was still running fine. I went to a repair shop for a check, and they said there was no problem and cleared the warning light. However, the warning light appeared again soon after, and the gear indicator keeps disappearing intermittently. Additionally, there's shaking when braking to a stop and when starting the vehicle. I'm seeking advice from the community!
I just bought a used 2013 model with a 2.0 automatic transmission. I've heard that its fuel consumption is quite high. I haven't even transferred ownership yet, and it's already worrying me.
