محمد عادل
2024-01-15 11:04
I just got a 2011 Mazda 5 a couple of days ago. After only two days, the check engine light came on with the code P2177. Can anyone help explain this?
Is this car going to be discontinued??? 🤔😭😭😭 I ordered this car on September 25th last month, and just got a call two days ago saying they can't fulfill the order??? What's going on?
I'd like to ask Mazda 5 owners, why is the noise level so high in this car? How can it be resolved, and how do you deal with valve cover oil leakage? What are your Mazda 5's fuel consumption rates in the city and on the highway? My 2011 automatic Mazda 5 costs 0.9 RMB per kilometer in the city.
Hey car enthusiasts, I've got a 2012 Mazda 5 that's had its gearbox repaired. How long can it last? Just bought it second-hand.
I bought a second-hand 2014 Kia Sportage, and the exhaust smells really bad. I hadn't driven it on the highway before, but a few days ago I did, and the engine warning light came on. The check indicated an issue with the oxygen sensor. After replacing it, the error code was cleared, but a few days later it came on again. It seems fine when not driving on the highway, but as soon as I do, the light comes on and stays on. Can any experts advise on how to fix this issue?
Picked up the car less than two months ago, got rear-ended with damages estimated at 40,000. Can I make him pay for the depreciation, guys? My heart aches.
Is it troublesome to replace the shock absorbers on a Mazda 6? I noticed during maintenance a few days ago that both the front and rear shock absorbers are starting to leak oil.
The engine warning light is on, indicating an oil leak. I changed the oil 4 days ago using 5-30w. What's going on? Does anyone know?
