عبدالله سعود
2023-04-12 11:00
11-year manual transmission, car powers on but won't start. Any experts here to help? 😊 Checked the fuse box too. 😢
عمر شعبان
عمر شعبان2023-04-27 00:12
Does your car key have a chip? Without a chip in the car key, it won't start.
هارون خالد
هارون خالد2023-04-18 22:26
The anti-theft chip in the key is having an issue.
حسن بوتفليقة
حسن بوتفليقة2023-04-16 22:09
Unlock issue?
سلمان علياء
سلمان علياء2023-04-12 18:15
The battery is dead.
If you are experiencing an issue with your Mitsubishi Galant where holding the lock button causes the yellow light to come on and the window control buttons become unresponsive, here are a few steps you can try: 1. **Reset the System**: Sometimes, simply turning off the car and restarting it can reset the electronic systems, including the window controls. 2. **Check the Fuses**: Locate the fuse box and check if any of the fuses related to the power windows or central locking system are blown. Replace any blown fuses with the correct type and rating. 3. **Inspect the Battery**: Ensure that your car battery is not low on charge, as insufficient power can cause electronic systems to malfunction. 4. **Consult the Manual**: Refer to your vehicle's owner manual for any specific troubleshooting steps related to the power windows and central locking system. 5. **Visit a Technician**: If none of the above steps work, it might be best to consult a professional mechanic or visit a Mitsubishi service center to diagnose and fix the issue. Please do not attempt to fix any electrical issues if you're not familiar with car electronics, as it might lead to further damage.
My radio keeps losing power, could you tell me where the fuse box is?
The car doors won't open in the morning, and the whole car is out of power. The reason is unknown. Could the experts please advise on the cause and how to fix it? Waiting for your help!!!
Is there any C40 owner who can help answer a few questions for this college student? It won't take much of your time. Mainly about the charging process of this car model, and it won't involve your privacy. I'm begging for help from the experts! [crying][crying][crying]
Are there any fellow car owners who have installed a dashcam? I bought one, but the 4S shop said they don't know how to install it. Just wondering, does the BRZ only have the fuse box in the engine compartment? How do you all get the power?
Why can't CarPlay connect? I've tried several different cables but still can't connect. Any experts here to help?
The trunk of the 2019 automatic luxury model won't open! What's going on? Can any experts help, please?
To check the fuse for the front left low beam on a Skoda, you should first refer to your vehicle's owner's manual. The manual typically contains a diagram showing the location of the fuse box and details about each fuse. In most Skoda models, the fuse box is usually located either under the dashboard on the driver's side or in the engine compartment. Once you locate the fuse box, look for the diagram that indicates which fuse corresponds to the low beam lights. Make sure to replace any blown fuse with one of the same amperage.
Where do you power your dashcam from? If you don't need parking monitoring, is it better to take power from the reading light, OBD, or the fuse box?
