علي إلياس
2024-11-21 20:57
Peugeot 4008,when the car is started with the air conditioning off, the radiator cooling fan doesn't turn, but when the air conditioning is on, the fan spins. Is this normal? Can someone knowledgeable explain this?
أبو بكر نايف
أبو بكر نايف2024-11-21 21:35
It's normal. When the air conditioning is on, the cooling fan must run. When the air conditioning is off, the fan only runs when the water temperature reaches a certain level. If the temperature is below the set level, the fan won't turn on.
How do you replace the air conditioning filter? Can someone explain it?
Is it normal for the radiator fan to keep running after turning off the engine when driving four to five kilometers in the city with the current weather?
The air conditioning in the 2011 Kia Sportage has cool air but isn't cooling effectively. What could be the reason?
Today, I went to the 4S shop to change the oil. When the car was lifted, I tried spinning one of the rear wheels by hand, but the other rear wheel didn't move. For a four-wheel drive, shouldn't turning one wheel cause the other to spin in the opposite direction, like the front wheels do? Can someone explain if this is normal?
At what temperature does the cooling fan of the Peugeot 207 start working?
Why isn't the air conditioning in my Alto cooling?
Is there anyone who understands why the air conditioning isn't cooling?
Hello everyone, my Peugeot 307's air conditioning isn't cooling, but sometimes after restarting, it cools again. What could generally be the problem?
The AC in my 2017 Peugeot 308 starts blowing hot air after a while, and the fan near the radiator isn't working. What's causing this problem? Does it require major repairs?
When I turn on the air conditioning, the cooling fan starts spinning, then stops after a while. The cycle of spinning and stopping is roughly one minute. Even after turning off the car, the fan keeps running and won't stop. Only by restarting the car and then turning it off again does the fan stop. Could the temperature sensor be malfunctioning? Any insights from the experts?
