محمد حارثي
2024-11-07 22:51
I used 5w30 oil, is that okay? The mechanic said it's the same.
Comments( 7 )
خالد نبراس
خالد نبراس2024-11-12 14:11
You can use it, but it's best to follow the model recommended in the maintenance manual. The recommended model has been tested over time and is the most stable and suitable option.
عبدالرحمن عبد الرحمن
عبدالرحمن عبد الرحمن2024-11-12 11:49
0W-30 and 5W-30 have the same oil viscosity at 30. The number before the "W" (which stands for winter) indicates the oil's flowability or viscosity at low winter temperatures. A lower number means better flowability at low temperatures, which is beneficial for cold starts or when the oil hasn't warmed up yet. However, even with 5W-30, it should still meet the ACEA C1/C2 standards, but it's best to follow your maintenance manual's recommendations.
علي قنصوح
علي قنصوح2024-11-11 16:41
I remember this 1.6T uses 0-30W C1/C2, and 5-30W is thicker, which might lead to oil consumption.
سلمان عائشة
سلمان عائشة2024-11-11 15:21
French cars have high requirements for engine oil. It's recommended not to switch brands casually. Don't trouble yourself for the sake of saving a few bucks.
محمد سلطان
محمد سلطان2024-11-08 21:08
Is this a 4S dealership?
عبدالرحمن عبد الوهاب
عبدالرحمن عبد الوهاب2024-11-08 17:50
It's difficult!
فرج علي
فرج علي2024-11-08 11:25
Stick to the maintenance manual [I need some peace and quiet]
What type of engine oil should I use for my X95? Is it the same type for all mileages? I'm currently at around 8,000 kilometers...
What type of oil is suitable for a 1.4 naturally aspirated manual engine? Is 5W-30 okay?
Is it okay to use 0W-20 oil for maintenance?
Can a 2009 Peugeot 307 hatchback automatic with 150,000 km go on the highway? I asked the repair shop, and they said it's okay for short distances, but not for long trips.
Yesterday, I went for a car maintenance, and the oil draining took a bit longer. The mechanic said that adding just over 4 liters of oil wasn't enough, so they added a bit more, totaling 5 liters. Is this reasonable?
I changed the transmission oil at 40,000 km at the 4S shop, and now at 100,000 km, I'm planning to replace it for the second time. I'm considering using Shell CVT transmission oil. Has anyone tried it? Is it okay to just clean the metal filter?
My 2009 Peugeot 307 has a transmission oil leak. I had it repaired once, but it's leaking again. The mechanic said that taking it apart for repairs would cost thousands and it's not worth it anymore. He suggested just adding some oil from time to time.
In 2009 Peugeot 307, the gearbox is slightly leaking oil. The mechanic said that if you want to repair the gearbox, it would cost a few thousand. If the leak isn't serious, you can just leave it and regularly add gearbox oil.
Hi everyone, could someone help me out? Where is the external transmission oil filter on the Acura TL? I'm getting my transmission oil changed, and the mechanic said this car doesn't have an external filter.
Hi everyone, for the transmission oil of Pama, should we use the original one or is ZF oil okay? ZF is half the price of the original. Some people say the original oil is also made by ZF.
