سعود سامر
2024-10-19 12:50
How does this car handle rough roads? I need to go into the mountains often. I've heard it's quite stiff. Is it a rigid stiffness or a more resilient one? Otherwise, I might choose the Tianyi.
خالد لقمان
خالد لقمان2024-10-20 11:43
The Peugeot 4008 handles mountain roads well, while the C5 Aircross feels a bit soft.
عمر نظيف
عمر نظيف2024-10-20 11:40
4008
محملة حسن
محملة حسن2024-10-20 11:13
On mountain roads, it's actually better for the car to be stiff. This car shows almost no body roll when cornering.
فهد نوح
فهد نوح2024-10-20 10:30
It's much harder. I just switched from the sedan 308 to the 4008 [I need a moment]. The chassis feels really stiff.
عمر طارق
عمر طارق2024-10-19 15:55
What are you going to the mountains for?
I heard that the 2.0 reservation channel will reopen in August, and the sales said it might be about 5% more expensive this time. Does anyone have any information on this?
I heard that the low-end Elite version doesn't have a car multimedia system. Does anyone know how to solve this? Can it be handled??
My Peugeot 207's suspension feels quite stiff. Is there something wrong? Has anyone else experienced a similar issue with their car? I have a 2013 Peugeot 207 sedan.
For daily use and light off-roading, which is more recommended between the V8 1UR engine and the 2UZ engine? I care more about failure rate and fuel consumption.
Why did you choose Jetta over Tan Yue? I compared the configurations, and Tan Yue has a lot more features.
If I add a turbo to a 2.5 Forester, can the transmission handle it? Or should I go for a stage 2 tune? The brake pads definitely need to be replaced, but I'm worried the transmission might not handle it, even though Subaru's transmissions are quite strong.
Which brand's A/T tires are good? I don't go off-road often. 🙏
How should I choose between this car and the Genesis G70? I'll be driving mostly myself, with occasional long road trips.
Do you feel that the chassis of your Xiaoqi feels a bit loose when going over rough and hard surfaces, like uphill and downhill? Mine feels a bit loose, and it's only 20,000 kilometers in. I usually don't drive on rough roads, just once on a mountain road with stone slabs and once over a speed bump in the parking lot, and it didn't feel good.
I got my car in August 2024, and when the left wheel goes over rough roads, there's a metallic clanking noise. What could be the issue?
