نايف سليم
2024-11-28 09:37
Hi everyone, I've had my 4008 Tech Edition for just over a month. Last week on the highway, the dashboard suddenly warned me to inflate the tires and reset something about the tires, which I forgot. I thought it was low on air, so I went to the shop to get it inflated, but the warning still shows. I'm totally confused right now. 😢
محمد سلطان
محمد سلطان2024-11-28 11:09
Reset the tire pressure monitoring system.
You can try the following steps to reset the tire pressure warning light: 1. **Check Tire Pressure:** First, ensure all your tires, including the spare, are inflated to the recommended pressure. 2. **Drive Your Car:** Sometimes, simply driving your car for a few miles can reset the warning light. 3. **Use the Reset Button:** Some vehicles have a reset button for the tire pressure monitoring system (TPMS). Check your owner's manual for its location and instructions. 4. **Disconnect the Battery:** As a last resort, you can disconnect the car battery for a few minutes to reset the system. However, this may reset other settings in your car. If the warning light remains on, there might be an issue with the TPMS or a tire. It’s best to consult a professional mechanic to diagnose the problem.
Why is the tire pressure warning light still on even though the display shows 220? It's been a week and it hasn't turned off.
Guys, my order was delayed until the end of 2022 or early 2023 last week. Did you guys get any updates? 😢
Hey folks, where do I reset the tire pressure?
How do I reset the tire pressure after a repair? It still shows low pressure on the right rear tire.
Today, I inflated the tire and reset the tire pressure, but it's still showing "monitoring" even after driving up to 25 km/h. I took it for a spin, but it didn't help.
Why do my Ariya tires need to be inflated every week? All four tires are losing air. I inflated them to 270 kPa, but after a week, they're only at 250-260 kPa.
Does this damage the primer? Will it rust later? Any knowledgeable brothers or masters here? 😢😢😢 Using a touch-up pen doesn't seem to last long, right? How should I deal with this? 😢
