Hello everyone, this time I used 5w30 oil for the change. I noticed the engine indicates 0w30. The mechanic said it's the same, not sure if that's okay.
Hello everyone! Has anyone replaced the air conditioning filter and adjusted the mechanical handbrake on a Kaiyi X3 themselves? A video would be great. Thanks again, everyone!
Hello everyone, after changing a pair of headlights, will it affect the annual inspection?
Hello everyone, how do you change the spare tire on a Toyota Fortuner?
4The mechanic said my radiator is leaking, but I haven't noticed any decrease in the coolant reservoir, and there haven't been any warnings on the dashboard. Should I replace the radiator now? Thanks for any advice!
5Hello everyone, does the original 2019 model come with a dashcam? I see there's a camera, but I'm not sure how to use it.
6Hello everyone! My 11-year-old Sunny with a manual transmission has run 100,000 kilometers. Do I need to change the belt now?
7My 2009 Peugeot 307 has a transmission oil leak. I had it repaired once, but it's leaking again. The mechanic said that taking it apart for repairs would cost thousands and it's not worth it anymore. He suggested just adding some oil from time to time.
8Hi everyone, could someone help me out? Where is the external transmission oil filter on the Acura TL? I'm getting my transmission oil changed, and the mechanic said this car doesn't have an external filter.
9Why is it indicating that I need to change the oil again when I just changed it in March?
10Hello everyone! Is it necessary to change brake fluid every 40,000 kilometers? How should I choose brake fluid? Which brand should I choose?
