Where can I find a dealer for exterior parts, interior parts, and water, oil, and electrical components for the Toyota 4Runner? I'm planning to make a purchase.
Where can I find a shop or parts to convert a 2012 Middle East version of the Previa to have electric sliding doors?
You can purchase welcome lights for your MDX from online retailers such as Amazon or eBay. Additionally, you may find them at automotive parts stores or websites that specialize in car accessories. Make sure to check the product specifications to ensure compatibility with your vehicle model.
4For a 2013 used Mitsubishi ASX 2.0 manual, it's said that the main components are imported. After purchase, aside from consumables like engine oil and brake parts, would other repairs be particularly expensive? Or should I just use aftermarket parts? I've driven company cars with 1.3L, 1.6L, 2.4L engines, front-wheel drive, rear-wheel drive, and manual transmissions.
5With a budget of around 100, you are looking for a 992s with four-wheel drive, in white with a red interior or in silver. At this price range, you might be able to find a used car in decent condition. The exact condition will depend on factors such as mileage, year of manufacture, and maintenance history. It's recommended to check the service record and perhaps get a professional inspection before purchasing to ensure the car's quality.
6Where can I find a 2023 model with a black exterior and red interior in stock?
7I recently got a 2013 1.4T VW Touran with 110,000 km on it. It's been owned by one person before me. Currently, the big electric fan isn't working, but the small one still is, and the water temperature isn't high. I'm planning to replace it in a few days. The only issue right now is a whistling noise in 5th gear at 70-80 km/h. It doesn't happen in 4th gear, only in 5th when I accelerate, and it stops when I release the gas. 🙂?️ Seeking advice from experts—is this a transmission problem?
82021 Outlander Vehicle Odor Issue. Background: Recently, the car was parked in an underground garage for a month, and the garage was somewhat damp. Situation: An unpleasant odor, like a musty and rotten smell, has started to accumulate inside the car. Self-assessment: I've checked the interior but couldn't find the source of the smell. I also replaced the air conditioning filter, and the air blowing out doesn't have any odor. However, as soon as the car is parked for half a day and I get back in, there is a strong smell in the cabin. The car has never been submerged in water or flooded before. Question: Has anyone experienced a similar issue and can provide some guidance on how to deal with this?
9I went to the Toyota 4S store yesterday to check out this car. The exterior and interior are both acceptable. I'm just a bit concerned about one thing: the particulate filter is located in the middle section of the exhaust, which is a bit far from the engine. Theoretically, since it's a naturally aspirated hybrid engine, the operating temperature is lower and the filter is farther from the engine. Wouldn't the particulate filter be more prone to clogging? What do you experts think about this issue?
10Looking to purchase a 2017 black exterior, black interior 3.6 Grand Cherokee!
