أحمد علياء
2022-06-19 02:02
What grade of oil should be used for Super Power?
حسين برهان2022-07-01 21:47
The manual specifies 0W-20.
عمر وسيم2022-06-19 09:27
0W20, 5W30, 5W20
How many liters and what grade of oil is needed for an oil change?
What type of oil should be used for a 1.5T engine?
4What oil does everyone use for maintenance? I'm using Mobil Super 1000 5W30, not sure if it's the right one.
5What's the engine oil grade listed in the maintenance manual for March? Thanks!
6What is the manufacturer-specified oil viscosity grade for the NV200?
7What grade of engine oil is suitable for a Sportage? Thanks.
8What grade of oil does your Sportage use?
9Should the Forester use Sinopec ethanol gasoline or PetroChina high-grade gasoline?
10What grade of engine oil do you use?
