سعود عفان
سعود عفان
Jan 18
I need help from everyone. When shifting from neutral to D gear, there's a noticeable jolt. What's causing this issue? Thanks a lot!
عبدالرحمن أبو بكر
عبدالرحمن أبو بكر2022-12-27 15:11
Common issues
حسن ابراهيم
حسن ابراهيم2022-01-28 16:55
Press the brake pedal a bit deeper.
سلمان مطلب
سلمان مطلب2022-01-24 16:30
Common Issue with Five-Speed Gearbox: It Gets Better in Hot Weather
ناصر محمد
ناصر محمد2022-01-24 13:41
Me too, the car just surges forward.
20
سعود عبد المجيد
سعود عبد المجيد2022-01-24 09:01
The car has a high idle and strong torque. Once you shift from N to D, it starts moving immediately, which is due to engine load. Also, make sure to press the brake pedal all the way down when shifting gears.
When shifting from reverse to neutral in the 2019 GA6, there's a vibration. What's causing this?
I want to buy a Kia Pegas for commuting, but I've heard from friends that when driving in D gear, you need to come to a complete stop to shift into 2nd gear. Is it really that troublesome?
Lately, I've noticed that when I start driving, the car stays in first gear until 2500 RPM and then suddenly shifts with a big jolt.
MG HS experiences a strong jolt when shifting from P to R or D when the car is cold. This has happened many times. When I went to the service center, the technician connected a computer and reprogrammed the transmission for gear learning. It got better, but after some time, the jolt returns when shifting gears with a cold engine.
Hi everyone, when I'm accelerating with my FJ and shifting gears, I notice that the shift from 4th to 5th gear feels more pronounced and abrupt. Is this normal? There are no error codes. It's not noticeable during normal driving, but if I deliberately pay attention to each gear shift, I can feel a slight jolt from 4th to 5th. To notice this, I have to keep the throttle steady without releasing or pressing it more. During the 4th to 5th shift, there's a noticeable abrupt feeling. However, if I ease off the throttle during the 4th to 5th shift, there's no issue at all. Any thoughts or suggestions are welcome. Thanks!
When shifting from D to neutral, there is a clicking sound. What could be the problem?
Is it normal to feel a jolt or a forward surge when shifting gears during acceleration?
Why is there an impact when shifting from R to D gear?
