عمر لهب
2023-03-21 08:46
I'm wondering if anyone knows what might be causing a noise from the rear wheels of a 2006 4Runner when going over bumps?
خالد طل
خالد طل2023-03-27 11:21
Is the suspension damaged?
Hey everyone, my 2006 car feels like it's jumping when turning over speed bumps or similar surfaces. Any idea what might be causing this? Thanks!
Help needed, the suspension of my V40 makes squeaky noises when getting in and out or going over speed bumps. I called for advice and they said it might be due to aging bushings. Has anyone else encountered this issue?
Anyone experiencing rear axle noise? The rear wheels aren't splayed, and there's no looseness, but on uneven roads, there’s always a rattling sound from beneath the rear seat. Does anyone know what the issue might be?
It's uncomfortable going over speed bumps, it's very bumpy. What's up with the suspension?
Hey folks, when my Sharan goes over bumps, I often hear a noise coming from the doors or the back seat. Does anyone know what might be causing this? Can the door gaps be adjusted? If so, how do you adjust them? Looking for some advice. Thanks!
Do you guys experience a squeaking sound when the front wheels go over a speed bump or curb?
Driving over speed bumps at 60 km/h can indeed have an impact on your car. It might cause stress to the suspension system, tires, and potentially the alignment. It's always best to slow down for speed bumps to avoid any potential damage.
Toyota Toyota 4Runner
Toyota 4RunnerAED 170,000Gasoline
