Hello everyone, when doing a minor maintenance on the Toyota Tundra, do you need to remove the skid plate to change the oil filter and drain the used oil? Or does the skid plate have an inspection port for changing the oil filter and draining the oil? I'm worried that if you have to remove the skid plate every time, it might wear out the threads on the original car frame, especially since some workers use electric tools for tightening.
How many liters of transmission oil does a Smart 4-door need for a change? Do I need to remove the oil pan and replace the filter?
What engine oil and oil filter are you all using? What's the price range you're going for? Thanks, everyone!
Can anyone teach me how to change the air conditioning filter? I can't remove the glove box.
4Do I need to remove the oil pan to change the oil?
5Do I need to remove the oil pan to change the transmission oil for the 2019 GAC GA5?
6What tool can be used to remove the air conditioning filter for the 2014 Peugeot 301?
7Can anyone discuss what type of oil should be used for a KAMIQ with a particulate filter?
8Q: For the Taurus 8AT transmission, is it necessary to use a circulation machine to change the transmission oil? Is it required to remove the oil pan for cleaning?
9Has anyone in the group changed the transmission oil for the 2021 JMC Ford Territory? This model doesn't have a transmission oil filter. Is it better to do a fluid exchange or a gravity drain by removing the oil pan? 🙏🙏
10How much and what type of oil should I use for a Cetus oil change?
