Sometimes when the clutch pedal doesn't come back up, what could be the reason? Does anyone know? Thanks.
Comments( 9 )
Today, my car sometimes shakes while driving. It shakes for about 2 minutes and then goes back to normal. Anyone know what the issue might be? Thanks in advance!
Sometimes, the middle door of my car closes halfway and then bounces back. Does anyone know why this happens?
What could be the reason for the Scirocco 2.0 engine warning light to turn off and then come back on again?
4The fan on my Sharan sometimes doesn't turn on even when the temperature is high. What could be the reason? Any advice?
5Could someone please explain why the air conditioning evaporator box might explode in a Changan Yuexiang? If anyone knows the reason, please reply. Thanks!
6My 2013 Sharan's electric door sometimes won't close by itself, and the button doesn't work either. After disconnecting and reconnecting the power, it works again. Does anyone know the reason?
7The transmission light on your car suddenly turned on for a few minutes and then went off. Sometimes it lights up while driving, but it hasn't come on in the past few days. What could be the reason?
8Car enthusiasts: Sometimes when driving a small car, the D gear won't shift up. The RPM suddenly goes up, but the gear doesn't match. What could be the reason?
9What could be the reason for the Haval H2's push-start sometimes working and sometimes not?
10In the morning, when starting the vehicle and driving at low speeds, it occasionally stalls. I've already cleaned the throttle and injectors, but it still stalls sometimes. If the speed picks up, it doesn't stall. What could be the reason? 🤦♂️
