علي فارس
2022-07-19 06:09
I have a manual 1.3 model from 2011. It's difficult to shift from first to second gear, and there's a loud gear noise. What could be the issue?
نايف حمدان
نايف حمدان2024-03-11 10:02
For a car of this year, you can first check if the transmission fluid needs to be replaced. If that's not the issue, then the clutch plates in the transmission might be severely worn out, and you'll need to repair the transmission.
حسين مرشد
حسين مرشد2023-01-08 21:44
Is the clutch okay?
عمر بكران
عمر بكران2022-07-28 01:35
I have the same issue as you, a clunking sound in 2nd gear.
عبد العزيز تميمي
عبد العزيز تميمي2022-07-22 23:25
My 2013 model makes a noise when shifting from 2nd to 3rd gear. The repair shop said it's because the gear cable rubber head is slightly off.
