محمد أكبر
2023-11-05 21:12
I have a 2012 automatic, and it often shifts to neutral when reversing, but there's no issue with driving forward. Has anyone encountered this problem? What could be the issue?
عبدالله عبيد
عبدالله عبيد2023-11-08 12:55
You should sell it quickly. Repairs could cost thousands, and there's no guarantee it'll be completely fixed. 😬
Is there a situation where it shifts to neutral by itself when reversing in reverse gear?
When shifting from reverse to neutral in the 2019 GA6, there's a vibration. What's causing this?
I've never encountered an issue with high water temperature in my car. There's no water leakage. What could be the problem?
Gear shifting issue: When the car is cold and I switch from reverse to drive, it rolls back a bit after releasing the brake before moving forward. This doesn't happen when the car is warm. Anyone else experiencing this? It's a 2019 model with 80,000 kilometers on it.
I have a question. Today while driving, I noticed that the gear shift lever on my automatic transmission can be shifted without pressing the button on the handle. Is this a problem?
Haval H2 automatic fashion 2019 model, when pressing the brake, it automatically shifts to neutral and can't shift back. You need to turn off the power and restart to be able to shift. There's no fault code on the screen. Any fellow car owners experiencing the same issue?
Jeep Liberty, 2012 model with over 170,000 km. It often stalls, especially when reversing with the AC on. When waiting at a red light with the brakes fully pressed and the AC on, it occasionally stalls too. I can't read any error codes. Does anyone know what might be the issue? Could it be a compression problem?
When shifting from D to neutral, there is a clicking sound. What could be the problem?
There's a noise when the car is in reverse gear, you can hear a creaking sound, but there's no issue in forward gears.
