خالد كريم
2022-07-22 09:35
I bought a used 2013 automatic car with 110,000 km on it. I've changed all the necessary oils and fluids, but the loudspeaker stops working whenever it rains and starts working again when the weather clears up. 🤦‍♂️ Could it be a wiring issue, guys?
نايف حمدان
نايف حمدان2024-03-12 11:29
Check if there's a poor seal on the wiring, aging or deformed door and window weatherstrips, and whether the car door drainage holes are blocked. Hope this helps you.
نايف حمدان
نايف حمدان2024-03-10 23:14
Check if the seals on the doors and windows are aging or deformed, which might cause poor sealing. Also, ensure the drainage holes in the doors aren't blocked. Lastly, inspect whether the loudspeaker wiring inside the car doors is properly wrapped.
سعود أنس
سعود أنس2022-09-02 11:53
I directly replaced the sound system, and the bass is so strong that the whole car shakes [I want some peace and quiet]
I just went to the 4S shop today, and I can't upgrade the car system. The original 360 camera is not clear and can't be calibrated. Regarding the transmission defect issue, the after-sales service at the 4S shop will apply to the manufacturer and get back to me. Also, I'm wondering if just changing the DSP will improve the original audio system since I don't like it. I'm considering the Pioneer 500A, which can connect directly with the original plug without installing separate loudspeaker wires.
When the air conditioning blows cold air for a while and then switches to hot air, and after being turned off for a bit, it works again before reverting to hot air, it's puzzling. Interestingly, this issue doesn't occur on rainy days or when the weather isn't too hot. What could be the cause of this situation?
If you want to add a reversing camera to your 207, you can follow these general steps: 1. **Choose a Compatible Camera**: Make sure the reversing camera is compatible with your Peugeot 207 model. 2. **Purchase Necessary Equipment**: You'll need the camera itself, a compatible monitor, and any necessary wiring or connection kits. 3. **Installation**: - **Mount the Camera**: Usually on the rear license plate area or bumper. - **Run the Wiring**: Connect the camera to the monitor and power source. This often involves routing the wires through the car's interior. - **Connect to Power**: Typically, the camera is powered by the reverse light circuit, so it activates when you shift into reverse. 4. **Testing**: Once installed, test to ensure the camera activates correctly and the image displays on the monitor. If you're not comfortable doing this yourself, it's a good idea to have a professional handle the installation to ensure everything works correctly.
Hi, for a 2011 Suzuki Swift 1.5 automatic that's run 110,000 km, here's what you might want to consider for maintenance to avoid getting ripped off: 1. **Oil Change**: Check and replace the engine oil and oil filter. 2. **Transmission Fluid**: Inspect and possibly replace the transmission fluid. 3. **Brake System**: Check the brake pads and brake fluid. 4. **Coolant**: Inspect the coolant level and top up or replace if necessary. 5. **Air Filter**: Check the air filter and replace if dirty. 6. **Tires**: Check tire pressure and tread wear. 7. **Battery**: Test the battery to ensure it's in good condition. 8. **Belts and Hoses**: Inspect for any wear and tear. It's always a good idea to consult your vehicle's manual or a trusted mechanic for specific recommendations.
After leaving the 2012 Koleos in an open-air parking lot for half a month during heavy rain, the keyless entry on the front doors suddenly stopped working, while the rear doors are fine. Has anyone experienced this situation? Is it a wiring issue or are the keyless entry sensors malfunctioning? PS: It's not a key battery issue.
BYD Song Plus 2.0 Fuel version, the windshield washer fluid doesn't spray out, but after driving for a while, it starts working again. What could be the problem?
