How do I turn on the high beams for a 2015 MG MG3? Please help.
My X95 manual's headlights have an issue. When I start the car and turn on the high beams, they don't work at all. But for a few seconds, they work fine. When the car is parked and I turn on the high beams, everything is fine. What could be the problem?
How do I turn on the high beams?
How to turn on the high beam headlights?
4How do you turn on the high beam for the 206? The low beams can be turned on and the high beams can be activated by pulling the switch back, but it can't be pushed forward. What's going on?
5How do I turn on the high beams for a 2015 MG MG3? Please help.
6How do I open the hood of a 207? I can't find it, please help 🙏
7Looking for help, how do I turn on the fog lights on the MG ZS? And where do I activate the external circulation?
8What is the wattage of the automatic headlights on the 2019 MG ZS, and are they integrated high and low beam?
9Who knows how to turn off adaptive high beams? I set it up and found that when I manually turn on the low beams, the dashboard indicator light goes off, and I still can't figure it out.
10I've checked the high and low beam lights outside the car, and they can be turned on and off normally. However, when I switch to the high beams, the dashboard keeps showing a "high beam fault," whereas there is no fault reported for the low beams. Can any experts advise on what exactly might be the problem?
